A/C in front will not cool and doesn't blow as hard. The back A/C blows good and is cool but not as cold as before.
Recharged with more freon but less than a week, back to not cooling again.
Is this a leak or something else?
SPONSORED LINKS
Saturday, May 17th, 2008 AT 4:07 PM
MASTERTECHTIM
MECHANIC
Did you vacuum the system before recharging? This is probably why not good cooling but you probably do have a leak. The low air flow from the front tells me the leak could be the evaporator core thats why the flow of air has slowed, due to partially plugged from leaking.
SPONSORED LINKS
Saturday, May 17th, 2008 AT 4:25 PM
CRAW4D
MEMBER
1 POST
I'M HAVING THE SAME EXACT PROBLEM ON MY 03 ESCALADE. THE FRONT JUST ALL OF A SUDDEN STOPPED COOLING BUT THE REAR KEPT COOLING BUT ONLY ABOUT 75% OF WHAT IT USED TO. THE COMPRESSOR WAS TURNING SO I WAS LOST. I PUT A GUAGE ON IT AND IT SHOWED TO BE FULL ON 134A, SO I PUT A LITTLE MORE IN TO SEE WHAT WOULD HAPPEN AND REALY NO CHANGE. DID YOU EVER COME UP WITH A FIX? THANKS, GREG
