2003 Chevy Tahoe 4X4 problem
INKEDUP
  • 2003 CHEVROLET TAHOE
  • V8
  • 4WD
  • 190,000 MILES
The service four wheel drive message comes on. I have replaced the selector switch on the dash. I also replaced the transfer case control module and had it programmed by the dealer. I changed the fluids in everything. Im down to maybe a transfer case motor or a speed sensor not sure. When I start it up the selector lights on the dash switch are supposed to stay where you left it but it has a mind of its own. It may start in low range, automatic, or really any of them, but what the main thing is when driving in 2 wheel after a block or so the transfer case kicks into neutral then I have to stop put the transmission in neutral then put it in auto 4 wheel to get to wherever im going. Let me know.
Tuesday, July 28th, 2009 AT 2:28 AM
  • 109,885 POSTS
It could be the actuator on the transfer case, but to me it sounds like there is an electrical problem. Have you checked the wiring harness to the actuator to make sure it is in good condition, clean and tight?
Wednesday, July 29th, 2009 AT 12:02 AM
INKEDUP
  • 8 POSTS
All the harness and connections are clean and tight any way to test the wires? I have a digital multimeter.
Wednesday, July 29th, 2009 AT 12:25 AM
  • 109,885 POSTS
If you want, you could have a helper changing the 4wd control in the vehicle to determine if you are getting power (when switched) to the harness.
Wednesday, July 29th, 2009 AT 11:56 AM
INKEDUP
  • 8 POSTS
Thanks for your input. I'm a mechanic by trade. Ive checked all the obvious things. I know its an electrical issue because the four wheel drive system has its own electrical system. The mechanical part is fine no noise or grinding. I'll just continue to replace parts till its fixed.
Wednesday, July 29th, 2009 AT 3:19 PM
INKEDUP
  • 8 POSTS
How do I get my money back. Im glad thats all I donated. I noticed people that didnt donate got better answers. Ill try it.
Thursday, July 30th, 2009 AT 12:37 PM
