2002 Chevy Tahoe Startup ticking
74,000 MILES • V8 • 4WD • AUTOMATIC
REDUFO
When I start the truck it ticks (sounds like a lifter) for a few seconds then stops. I've had this vehicle serviced at the dealer. A friend told me this truck could use two differend oild filters and I needed to make sure they were using the right one. I look in the book and the filter mathces the book. Is there another oil filter I should be using.
Feb 11, 2008 at 10:58 PM
2CARPRO JACK
  • 11,533 POSTS
According to my catalugue it uses an A/C Delco #PF46 be sure that you are using the correct weight of oil, this will have something to do with how fast it oils on start up
Feb 12, 2008 at 2:43 AM
