2002 Chevy Tahoe Engin Noise
86,000 MILES • V8 • 4WD • AUTOMATIC
RICCARDO458
Hello, in the morning when I first start up my tahoe Z71 my engine seams to make alot of noise, sounds like the rods are nocking sounds like its out of oil, after about 30 to 40 seconds the noises goes away I check the oil .its ok , I had The oil changes and use suv oil, but it stills does it , I have ask others with the same car and they tell me they don't have that proplem , is there anything I need to know or do .. Thanks Richard in the bay area
Jan 22, 2008 at 4:46 AM
RICCARDO458
[quote:49a6ef25cb="riccardo458"]Engine problem
2002 Chevy Tahoe V8 Four Wheel Drive Automatic 86,000 miles
Hello, in the morning when I first start up my tahoe Z71 my engine seams to make alot of noise, sounds like the rods are nocking sounds like its out of oil, after about 30 to 40 seconds the noises goes away I check the oil .its ok , I had The oil changes and use suv oil, but it stills does it , I have ask others with the same car and they tell me they don't have that proplem , is there anything I need to know or do .. Thanks Richard in the bay area[/quote:49a6ef25cb]
Jan 22, 2008 at 4:49 AM
  • 75,988 POSTS
Sir
You need to have the oil pressure checked-if its normal-most likely you have a lifter/s leakddown problem-its always like that when it pumps up and the lifters filled up.
Jan 22, 2008 at 5:08 AM
