2002 Chevy Tahoe check engine soon
JMTC
  • 2002 CHEVROLET TAHOE
  • V8
  • 78,950 MILES
Car is running fine but check engine soon light came on, can I wait until next week to get car in or should I get it in right away?
I have already had to have the transmission rebuilt and I get the oil changed on a regular basis
Friday, January 16th, 2009 AT 4:52 PM
PEAR69
  • 1,482 POSTS
You should have the computer scanned. If you have a mechanic scan it he (or she) will probably charge you. You can have Autozone or a place like that scan the computer for you for FREE. They will give you the code and you can let us know what the code is and we can take it from there. If you do not work on your tahoe, we can tell you what the code is, so you will have a "heads up" when you take your tahoe to a mechanic. If the engine is running fine it is probably something minor - like a bad gas cap or loose gas cap - common issue. But it can be something that can lead up to a bigger issue so have the computer scanned.
Saturday, January 17th, 2009 AT 3:42 PM
