What indications might this indicator suggest is faulty
Monday, January 19th, 2009 AT 8:42 PM
BLUELIGHTNIN6
MECHANIC
There are hundreds of things that will cause the engine light to appear. You need to have the codes scanned. You can do this at a local part store such as AutoZone or Advance Auto Part for free of charge. Post the code numbers and I will help you with the diagnosis.
