Ive had my tahoe into the shop 6 times for the same problem they have changed my pump and relay and filter out 6 time and it will work for a while than will die while running or will not fire, it cranks fine, if I have it towed some times it will fire up at the shop and the fuel pressure will read ok idle is at 500
SPONSORED LINKS
Thursday, June 17th, 2010 AT 11:18 AM
