1999 Chevy Tahoe Tahoe shakey gas gauge indicator
CAPTOFD
  • 1999 CHEVROLET TAHOE
  • V8
  • 4WD
  • 125,000 MILES
My 99 Tahoe has a gas gauge indicator needle
that vibrates or shakes after the key is turned on.
Still reads tank level acturately, but vibrates. All other gauges OK.
By chance my fuel pump just failed(after this problem started), replaced in-tank pump assembly and check grounds at tank end. All OK. Shakey gauge before and after pump replacement. Where do I look next?
Thanks,
Jeff
Tuesday, September 9th, 2008 AT 12:12 PM
TOSEVSKI79
Hi there, same problem. But my problem also consists of not having a spark. Changed everything, dist, cap, button, leads, spark plugs, new pcm, angle sensor. Still having the same problem?
Thursday, September 11th, 2008 AT 8:08 PM
