1999 Chevy Tahoe Fuel pump, fuses
TEAM TESTER
  • 1999 CHEVROLET TAHOE
  • V8
  • 4WD
  • 130,000 MILES
I have a 99 Tahoe that I have replaced the fuel pump on at least three different times. Well this last time after I got it in, and turned the key over, it started popping fuses. It has never done this before after replacing the fuel pump. I am at a loss for what to do now.
Friday, September 10th, 2010 AT 1:12 PM
Hi Team Tester, Welcome to 2carpros and TY for the donation
Disconnect the fuel pump connector and see if it pops the fuse-let me know-
Friday, September 10th, 2010 AT 4:14 PM
TEAM TESTER
Okay, so we disconnected the relay and it blew the fuse still. So we disconnected the fuel pump itself and it still blew a fuse. Also now my fuel gauge in my dash is pointing straight down and doesn't move when the battery is disconnected and reconnected.
We have replaced the fuel pump 4 times now, and never had these issues before. We double checked the wiring going into the fuel pump and it is fine.
So now we are at a loss for what to do next. Any suggestions?
Tuesday, September 14th, 2010 AT 10:41 PM
The fuse you're talking about is it the Ign E 10amp?
Wednesday, September 15th, 2010 AT 2:03 PM
TEAM TESTER
No it's one of the 20 amp fuses.
Thursday, September 16th, 2010 AT 9:40 AM
What is the fuse amp and what does it powers, you need a professional help here this can drag on if you're lacking electrical experience -let me know
Thursday, September 16th, 2010 AT 5:03 PM
