1999 Chevy Tahoe Flywheel
MUSTANGROMI
1999 Chevy Tahoe Four Wheel Drive
I'm trying to replace the flywheel on my 99 Tahoe. I have removed all the bolts from the underside of the car. First question: Are there more bolts on the top side? Second question: I'm trying to push back the trans so I can get to the flywheel, but it's not budging, which leads me to believe there are more bolts topside. I can't see them and it's hard to get to. Is there a trick this job? Any suggestions would be great!
Thanks
Jun 28, 2010 at 1:03 AM
  • 31,937 POSTS
You will have to remove the cross member and lower the trans down a bit to access the top bolts, leave a lower bolt in place remove all top bolts, leave one bolt in for safety until the transmission is ready to be removed.
mark (mhpautos)
Jun 28, 2010 at 2:21 AM
