Electrical problem
1999 Chevy Tahoe V8 Four Wheel Drive Automatic 150k miles
I have a 1999 Chevy Tahoe, It is running a little rough. It keeps blowing out the 20a ENG-I fuse in the engine bay, once that fuse gets blown it triggers the codes p0340 and p0102. Ive unplugged the 4 o2 sensors and then tried it and it still blew the fuse, i also tried the maf sensor, i think the cam position sensor (the plug-in into the distributor), and the purge canister on the drivers side. What else might be causing the fuses to keep blowing and the codes to come up? The fuses only get blown when i start the truck.
Dec 15, 2008 at 11:27 AM
