1998 Chevy Tahoe Hesisitation
1998 CHEVROLET TAHOE
169,000 MILES • V8 • 2WD • AUTOMATIC
LASHUN.MCKNIGHT
Hello! My vehicle only has hesisitation and "misses" when it rains or it is damp in the air. This has just started about a month ago? It seems to backfire when i crank it - it has gotten to where it does that often? What causes this
Feb 22, 2010 at 6:54 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 22, 2010 at 2:15 PM
