1998 Chevy Tahoe Brake problem
88,055 MILES • V8 • 4WD • AUTOMATIC
RF523
My wife was driving the truck when it sounded like she ran over a rock. The the right rear brake started making noise and the entire brake system seemed like it was working at 1/2 efficiency. I checked the fluid and it is OK. I also checked the wheels. There is a line that runs to the front of the wheel from inside that seems very loose on the right side. The same line on the left side is not near as loose. When the emergency brake is applied, this line tighens up. What could the problem(s) be?
Jan 13, 2008 at 10:06 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a7d6935695="rf523"]Brakes problem
1998 Chevy Tahoe V8 Four Wheel Drive Automatic 88055 miles
My wife was driving the truck when it sounded like she ran over a rock. The the right rear brake started making noise and the entire brake system seemed like it was working at 1/2 efficiency. I checked the fluid and it is OK. I also checked the wheels. There is a line that runs to the front of the wheel from inside that seems very loose on the right side. The same line on the left side is not near as loose. When the emergency brake is applied, this line tighens up. What could the problem(s) be?[/quote:a7d6935695]
you need to pull tires out and then drums and check the brakes
the line you are looking at if no fluid leak you don’t need to worry about them
Jan 13, 2008 at 12:14 PM
