1997 Chevy Tahoe Will not shift from park to any gear
1997 CHEVROLET TAHOE
183,000 MILES • V8 • 2WD • AUTOMATIC
KTIBBS0301
My chevy tahoe will not shift from park to any position or gear at times. It dont do it all the time just on occasion. I have to turn the key half way on and then it will shift into any position.
Jun 14, 2008 at 12:38 AM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
As a 1st step check brake light switch and its connector plug
Jun 14, 2008 at 6:52 AM
JCLICK
Where is the brake light switch located?
Aug 6, 2008 at 8:25 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
mounted on top the brake pedal
Aug 6, 2008 at 9:37 PM
JCLICK
Thanks. We had Uhaul install trailer brakes in our truck about a month ago. From the instructions on the brakes, it looks as if it is tied in to the same button as is mentioned in this thread. Maybe they messed something up when installing the unit. Thanks again for the help.
Aug 7, 2008 at 4:43 AM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
check fuses
possible that the fuse couldn’t handle the load
check for a cut wire also around the switch
turn key to position 1 shift to neutral start engine
(dont put it in park until u reached u r destination )
Aug 7, 2008 at 6:34 AM
