1997 Chevy Tahoe No fuel to engine!
MTMCGRATH
  • 1997 CHEVROLET TAHOE
  • V8
  • 126,000 MILES
I tested the truck with a light and found voltage all the way to the fuel pump. Granted, the light as dim, but maybe it was due to a lower voltage ratting. I removed the tank, pulled out the old pump assy. And found that it didn't work. To make sure, I connected the new one and found that it did work. But seemed a bit slower than normal. I installed the new unit, put everything back together, and started the truck. It ran great for about 2 to 3 min. And then it died. I am not able to get it started again. Can someone tell me what the voltage should be, tired of reading all of my books. Or, let me know what the code would be if I'm able to pick up a tester.
Thank you!
Retired Vet!
Friday, January 11th, 2008 AT 1:16 PM
FISHERMAN
  • 937 POSTS
Hello !
The voltage at the pump should read 12-14 volts Direct current ( the same voltage from your battery)
Check the connector plug for proper voltage at thye pump, also check your voltage at your battery (clean and re-tight the connectors on battery posts)
good Luck and let us Know!
Friday, January 11th, 2008 AT 3:50 PM
