While turning gently to the right at high speeds (>50 mph) which is common on high speed exit ramps, I hear a humming noise. It appears like tire noise, but only occurs while turning to the right. It is most pronounced while I am coasting or braking. If I accelerate, the noise dies down or goes away. It will occasionally make the same noise, but a lot less loudly when I coast down a hill.
Rear wheel bearings and seals were replaced (replaced bearing at the same time as the worn out seals), but did not correct the problem. All drivetrain fluid levels are OK.
Any ideas?
Any ideas?
Feb 7, 2009 at 3:05 PM
