2005 Chevy Suburban Gone crazy!
60,000 MILES • V8 • 4WD • AUTOMATIC
DARREN928
My 05 Suburban has gone completely nuts! This morning I started the car to find many of the electrical items were not functioning at all or not functioning correctly. For example, when running, most guages dont work, all dome and reading lights are on, only the rear windows roll down, the AC doesnt work, etc. However, some of these items seem to function when the vehicle is not running but the key is in the accesory mode. I have a code reader but it is not much help and claims that the ignition is not in the "run" position when in fact it is...so no help there. There is a posibility of rodent activity although I see no visible signs. I do however live in the country and just last week suffered some rodent related damage to my 08 Tundra. Any advise?
Feb 23, 2009 at 10:44 AM
KHLOW2008
  • 41,812 POSTS
Hi Darren928,
Thank you for the donation.
When items works with key in ACC and not in RUN position, the most likely cause would be a faulty ignition switch. I would suggest testing the ignition switch power input and output.
That would also cause the reader to say the ignition is not in RUN position.
Feb 24, 2009 at 6:17 AM
