2005 Chevy Suburban Air Conditioning
JAGMANUSMC
  • 2005 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 42,000 MILES
I just had the battery replaced and now the A/C will not work on the driver side. It blows hot air just fine. The passenger and rear A/C is working just fine. I am baffled. Please help.
Sunday, July 19th, 2009 AT 2:49 PM
87BANSHEE
  • 15 POSTS
New Battery would have anything to do with this problem. Sounds like the temp. Actuator is not working for the passenger side. You need a scan tool to check for codes and also to calibrate the actuators. If this doesn't work you most likely need a new temp. Actuator.
Monday, July 20th, 2009 AT 9:02 AM
CRUISIN2WHLSHD76
Thats the same thing that happen to my 2005 surburban
I removed the battery, and when I re-installed it the passenger side was doing the same thing, blowing very hot air. Any help?
Monday, September 14th, 2009 AT 9:10 PM
JAGMANUSMC
It fixed itself after a few re-starts. Still goes out every once in a while - but by re-starting the car, the system re-boots I guess. Will need to get it fixed, but living in Yuma, AZ puts A/C repair issues at a very high cost, so going to live with it until stationed back east where they have winters.
Friday, September 18th, 2009 AT 8:40 AM
