I just replaced the manifold gaskets to fix a problem with the original gaskets but now I get a very strong gas small after starting and going to an idle. The engine is running fine with no check engine light coming on. I am wondering if the computer that runs the fuel pump was overcompensating for the leaky manifold gaskets and now that shows up as the strong gas smell. Should I reset the computer to bring it back to original settings? If so is the a fuse to pull to reset the computer in charge of the fuel pump?
Thanks
Thanks
Dec 22, 2008 at 4:10 AM
