2002 Chevy Suburban Suburban doesn't like car washes
JDPMN1
  • 2002 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 124,000 MILES
Factory Air Filter, Flex Fuel Engine
When I run my vehicle through a car wash the "check engine light" comes on. The engine runs fine for the first 3 minutes or so, then will start to run rough, then the light comes on.
I have had the codes read:
P0171, P0174 "both banks running lean".
Here is what I have done so far:
checked vacuum - normal and strong, consistent
replaced MAF, then cleaned the new MAF
replaced plug wires
replaced pcv
replaced fuel filter
The vehicle does not have any performance problems outside of the car wash.
Sunday, February 24th, 2008 AT 9:38 PM
2CARPRO JACK
  • 11,533 POSTS
Check for water contamination in the o2 sensor connectors and every other connector under the truck. Im thinking you will find something there, very difficult to get water under the hood
Monday, February 25th, 2008 AT 11:56 AM
