2001 Chevy Suburban Low oil pressure only at idle
2001 CHEVROLET SUBURBAN
129,000 MILES • V8 • 2WD • AUTOMATIC
STENSRUDE
I just purchased an '01 Suburban and notice now that the oil pressure drops (to about 7-8psi) and the check engine oil light comes on when the car is at idle/ decelerating. I've had the pressure mechanicaly checked which confirmed the low oil pressure, the sensor was also replaced because it was a very cheap model..but still having the same issue.
Is it possible to diagnose the problem given this information...i've been told that it could be
1. Oil screen inside the oil pan
2. Oil Pump
3. Excessive Engine wear
Please help!
Apr 20, 2010 at 11:56 AM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Hi stensrude. Welcome to the forum. All three of those are possibilities. If the pickup screen is partially blocked, pressure will be low when the engine is first started and is still cold and the oil is thicker. Pressure will be higher at idle if the problem is related to bearing wear. The pressure will also go up, if bearings are the cause, if you use a higher viscosity oil or if you add a "viscosity index improver" such as STP. The additives only do the same thing as using the higher viscosity oils.
The clue too against the pickup screen being blocked is if pressure goes up when engine rpm goes up. That suggests higher volume overcomes the higher than normal internal leakage past the bearings. A blocked screen won't allow a higher volume.
caradiodoc
Apr 20, 2010 at 12:15 PM
STENSRUDE
Alright I added about half a bottle of STP oil treatment, and this does help when the car is first turned on (before adding the stp it had low oil pressure at idle and start up) now it has good 20psi at start up and stays there untill the car is warmed up (at which time it maintains the 20psi while driving but drops to low oil pressure when stoped or slowing down.
Is there any bennefit to changing the oil with a much heavier weight or would that be the exact same as what i've got now with the STP?
Apr 22, 2010 at 7:41 AM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
If the pressure was already low at startup when the engine was cold, I'd be leaning more toward a worn oil pump. It's hard to make a judgement call based on mileage because neither the pump nor the bearings should show excessive wear yet. The place to start is by insecting the crankshaft and connecting rod bearings. That's really not a very serious undertaking. It just requires draining the oil and removing the oil pan. If excessive clearance is found, technically the proper repair is to remove the crankshaft, have it machined and polished, and install matching under-size bearings. But removing the crankshaft involves removing the engine or transmission, so a lot of people just install new bearings with generally positive results. If simple bearing wear is the cause, oil pressure will be restored. If a bearing is "spun", meaning it has a rough, ground up surface, the crankshaft journal will also be severely damaged, and you'd be hearing banging noises too.
If bearing clearances are ok, put the new oil pump in. They are relatively inexpensive and provide cheap insurance. Be sure to insect the pickup screen for looseness.
Since the STP helped, go with a higher viscosity oil at the next oil change. You should not have to use an additive at every oil change as it only provides the same increased thickness the higher weight oil provides. You might also try a straight weight oil such as 30W or even 40W. These are not good choices for cold winter climates because they can cause hard starting due to low cranking speed, and it can put added stress on the shaft for shaft-driven oil pumps. I've only read about those shafts breaking a couple of times but why risk it?
caradiodoc
Apr 22, 2010 at 2:22 PM
STENSRUDE
Thanks again for the advice, Since I'm in san antonio, TX i doubt i'll need to worry about the cold winters anytime soon--but more importantly the 100 degree summer days that are fast approaching. I'm busy this week, but next week i can do some exploring...are these all things that i can handle myself? If i drop the oil pan, I can first inspect the pick up screen/tube, then use your plastiguage idea to check the clearances....if neighter of these appear to be damaged does that leave only the pump or could something else be the cause?
I'm much less nervous then i first was about this..i'm hoping and praying that it's just a pump and can be replaced relatively cheap and painless...
Apr 22, 2010 at 3:19 PM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Can I move in with you? I live through Wisconsin winters!!!
You can tackle the bearings if you're mechanically-inclined. Be sure to put the caps on with a torque wrench. It will be helpful to have a service manual. I'm pretty linited on what I have for GM. What little I do have is not original so there's a chance the torque specs could be wrong.
Do you know how to use Plasti-gauge? Parts stores or engine machine shops that sell it can show you how to use it.
You might want to look at (examine) a new oil pump first. It used to be a heavy cast iron square block that bolted onto the bottom of the engine, but a lot of engines have been redesigned using a big aluminum plate that bolts onto the front of the engine and is run by the crankshaft snout. To change this style, it is usually necessary to remove a few of the front oil pan bolts so having the pan off already makes it easier. This style pump also requires removal of the timing chain. Due to valve spring pressure, it is common for the camshaft to turn a little when the chain is removed, so be sure you see where the timing marks are or mark them for future reassembly. Hopefully your pump is still on the bottom of the engine. That style is a lot easier to replace.
caradiodoc
Apr 22, 2010 at 3:52 PM
