HI there,
Thank you for the donation'
You will have to get a cooling system pressure test done, have it done hot and with the heaters on, this will locate any external coolant leaks, also I would suggest a cooling system Co test, this will pick up any traces of Co in the cooling system and if so this is a sure sine of a head or gasket problem, start here.
Mark (mhpautos)
SPONSORED LINKS
Friday, December 18th, 2009 AT 8:19 PM
