Loose steering
1999 CHEVROLET SUBURBAN
220,000 MILES • V8 • 4WD • AUTOMATIC
ROBERT.ANDERSON04
My steering feels loose when I drive my Suburban. It tends to want to sway from side to side. I have replaced all the tie rods and the ball joints. I have had the front end checked out at a shop and had the alignment done. Is it te steering box going bad or do I need to install a steering stabilizer cylinder kit?
May 4, 2009 at 11:31 AM
ZACKMAN
  • 4,202 POSTS
Yes this truck had problem with the steering box here is a video that shows how to replace it.
https://youtu.be/KKeFqHLuRQ0
Cheers
May 10, 2009 at 12:51 PM
STEVE KYLLONEN
  • 7 POSTS
I suspect gear box is bad, I replaced all other front end parts and steering is still loose. would like to see inside picture of gear box.Do they go bad?, if so first experience.
Jul 31, 2018 at 6:37 AM (Merged)
CARADIODOC
  • 34,381 POSTS
Have a helper move the steering wheel rapidly back and forth about 6" while you watch the input shaft at the gearbox. The pitman shaft should turn at the same time. If there is a lag before it starts to turn, there are two possibilities. If the pitman shaft moves sideways a tiny but noticeable amount, bottoms out, THEN starts to turn, the bushing is worn and the gearbox must be replaced. More likely the sector shaft needs to be adjusted. That is done by loosening the lock nut on top and tightening the center bolt. The center bolt usually takes a 5/32" allen wrench. Just tighten it 1/8 turn and try it. Overtightening it will cause it to bind when steering straight ahead and will be irritating to drive. Tighten it another 1/8 turn if its getting better, but remember where you started from.
caradiodoc
STEVE KYLLONEN
  • 7 POSTS
Awesome, Thank you.
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
TALLFRIE
While driving at speeds of over thirty mph or so when I go around right hand tuns I loose tension in the steering wheel for a second or so and then it comes back. It is a bit scary and only happens while steering to the right.
Thanks for your help,
Jeff
Jul 31, 2018 at 6:38 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Check out belt and tensioner belt maybe slipping
SHANE1989
hi my name is shane and i have a 1999 chevy suburban 1500 2wd and a little while back the steering has become very loose. i can turn the wheel left and right quite a bit before there is any response from the wheels themself. how exactly can i fix this problem.
GBGTEXAS
  • 46 POSTS
[quote:a8668ea6d2="shane1989"]hi my name is shane and i have a 1999 chevy suburban 1500 2wd and a little while back the steering has become very loose. i can turn the wheel left and right quite a bit before there is any response from the wheels themself. how exactly can i fix this problem.[/quote:a8668ea6d2]
you need to have the front suspension/steering linkage checked. You will probably find that you have a worn/loose pitman arm or possible gear box problems.
