1999 Chevy Suburban fuel related
160,000 MILES • V8 • 4WD • AUTOMATIC
GENE W
once in a while driving car will die . crank and crank will not start .spray with starting fluid will start but die again. let set for @10min. or so will start and run untill next time. could it be fuel pressure regulator? Thanks Gene
Nov 22, 2009 at 12:59 AM
JDL
  • 16,098 POSTS
Welcome to the forum, use a gage and check fuel pressure. 5.7 litre engine, 60-66 psi, key on engine off. When the problem occurs, use a noid lite, check for injector pulse.
Nov 22, 2009 at 2:14 AM
