Battery drain
TROSECKE
  • 1999 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 130,000 MILES
I have a 1999 chevrolet suburban, and I keep on having a dead battery. I have changed out the battery twice and had the alternator tested which tested good. I do not know where else to go on this matter. I also thought that if I disconnect the positive on the battery and use a meter, by connecting the meter between the battery positive and the cable I might be able to see if there was a power drain somewhere. When I did this, I took the reading and then I started to pull fuses to see if it would change up or down, but nothing. Any help you could give would be greatly appreciated.
Sunday, April 27th, 2008 AT 7:44 PM
I have seen where a CD will get stuck int he player which runs the motor and drains the battery down here is a guide to help you see all the regular places to look for a battery draw.
https://www.2carpros.com/articles/car-battery-dead-overnight
Cheers
Monday, April 28th, 2008 AT 6:43 AM
