1999 Chevy Suburban V8 Two Wheel Drive 121000 miles
The Service Engine Soon light illuminated and I had the fault codes downloaded. The code was for the #2 cylinder misfire. I reset the code and pulled, cleaned and regapped the #2 plug. The light came on again. It seems to occur only when the engine is under a heavy load (pulling RV uphill). Given that the condition seems to occur only under a load, what would you suggest on the correction sequence?
SPONSORED LINKS
Wednesday, December 26th, 2007 AT 1:45 PM
