1997 Chevy Suburban a clank or pop after I shut off the bur
1997 CHEVROLET SUBURBAN
208,000 MILES • V8 • 4WD • AUTOMATIC
KMBRYAN
Each and every time I shut off the burb, wait about 5 minutes and it will make a noise as if the gas tank is expanding or something. I did purchase a new gas cap and I have been using unleaded + , and have on more than one occasion put gas additive in to clean it up. But this problem has been going on for over a year even prior to me doing anything to it. I can shut off the burb in the garage and walk into the house and 5 minutes later I can hear the pop happen, it's as if you take a can and bearly crunch it then fill it up again and hear it expand. What would cause this?
Jan 21, 2010 at 12:01 PM
  • 110,244 POSTS
The pump does create a strong vacuum. However, there is a one way vent that should allow air to be drawn into the tank but not allow air out. I believe it is located on the rear of the tank near the axle. Check that to make sure it is allowing air to enter the tank as needed.
Jan 22, 2010 at 3:19 AM
