1997 Chevy Suburban
HERMAN.NASH
  • 1997 CHEVROLET SUBURBAN
Air Conditioning problem
1997 Chevy Suburban V8 Four Wheel Drive Automatic
The compressor come on by its self
Friday, February 5th, 2010 AT 12:50 PM
JDL
  • 16,098 POSTS
Hi, there is a compressor relay, voltage to the relay goes hot when you turn on the key. The PCM grounds the coil side of relay in order to energize relay. The pcm won't ground the relay without request. The request comes from the hvac control module. I'd check for any possible trouble codes, to see if a code could point me in the right direction, otherwise, I'd have to backtrack the circuit.
Friday, February 5th, 2010 AT 1:27 PM
