1996 Chevy Suburban rear planetary gear
MARIBELLE
  • 1996 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 203,000 MILES
This gear is broken and needs replacing. We use the car only for bad weather and for carrying larger loads than our others can handle (like moving kids to college). Is this worth replacing?
Monday, January 19th, 2009 AT 8:37 PM
THIS IS MIKE
  • 686 POSTS
Replacing the gear set can be expensive, if you only use the car occasionally then it may not be worth it to fix with new. You may be able to find a used rear end and just swap it for less.
Wednesday, January 21st, 2009 AT 11:14 AM
Related General Content
