1996 Chevy Suburban Heater not putting out enough heat
165,000 MILES • V8 • 4WD • AUTOMATIC
AMFPCHAP
I recently had the engine replaced with a remanufactured, warranteed engine. Before the engine was replaced the heater worked great. Now it doesn't produce enough heat at the heater vents. I took it in to the shop that did the engine work and they put a higher temp thermostat in but it still isn't working right. When I am driving if I accelerate the heater puts out plenty of heat but only for a few seconds. The shop recommended replacing the heater core but it seems to have enough hot water in it.
Dec 10, 2009 at 8:21 AM
  • 75,988 POSTS
Hi amfpchap and TY for the donation
Sounds more like a door problems with air mix/blend/mode-not doing its job or vacuum and actuators not functioning to include the HVAC control module
Dec 10, 2009 at 8:33 AM
