1995 Chevy Suburban Slight Miss
16,500 MILES • V8 • 2WD • AUTOMATIC
BRIAN.HUTCHENS
My 1995 Suburban has a slight miss particularly at a braked stop but also in park. I have recently done a full tune up; plugs, wires distributor, rotor button, cleaned K&N airfilter, PCV, and fuel filter and still have the small falter. Tach indicates about a 100 to 200 RPM drop. No check engine light. Seem to run well. Nervous because I am about to drive from Alask to North Carolina pulling a light (2,00 lb) pop up camper and the family. Do not wish to get stuck in Cananda with broke 'burb.
Also outside air blows on my feet when AC / vent and heat is off.
May 30, 2008 at 10:49 AM
MMPRINCE4000
  • 8,548 POSTS
Do a compression test on each cylinder, and check fuel pressure.
If equipped with port injection, test each injector with a noid light.
Also make sure all the grounds are clean and tight.
If everything above checks out I would replace ignition coil and pickup coil.
May 30, 2008 at 9:53 PM
