1993 Chevy Suburban
DICKQCY
  • 1993 CHEVROLET SUBURBAN
Engine Mechanical problem
1993 Chevy Suburban V8 Two Wheel Drive Automatic
setting distributer and timing in rebuilt 1993 5.7 big block core
Tuesday, September 29th, 2009 AT 8:41 AM
HMAC300
  • 48,601 POSTS
#1 is the front left-driver's side. Rotor in distributor should be pointing to about 11:30 position on clock. It will look like it is pointing to the #1 cylinder. There should be a brown wire in the harness on the firewall to disconnect to set the timing. Distributor will trun clockwise.
Tuesday, October 6th, 2009 AT 6:04 PM
