1986 Chevy Suburban oil in the exhaust
91,000 MILES • V8 • 4WD • AUTOMATIC
KWSTINE86
I have a 1986 chevy k20 suburban recently developed an oil leak in the exhaust in the #1 cylinder i think but its in the exhaust only there isnt any oil on any of the spark plugs.
any Ideas what this may be and how do I correct it the motor only has about 8000 on a rebuild.
Please help.
Jul 26, 2010 at 8:44 AM
  • 75,988 POSTS
Hi kwstine86, Welcome to 2carpros and TY for the donation the site appreciates it to keep helping
You need to perform a combination tests -check the engine compression both wet and dry tests and follow it with a cylinder leakdown test. Doing this will pin point where its leaking could be valves/rings and cylinder wear
Jul 26, 2010 at 10:01 AM
