1985 Chevy Spectrum overheat
75,000 MILES • 4 CYL • FWD • AUTOMATIC
MOKEA
My chevy spectrum's upper radiator hose bursted and since then it runs hot whenever i turn it on.It doesnt matter if idling or driving. I replaced the hoses, thermostat and fluid. Still runs hot. Is this a chain reaction from the bursted hose? What are the possible other reasons for the overheating?
Aug 31, 2009 at 4:49 AM
JDL
  • 16,098 POSTS
Other than the temp gage, are there any other indications of the engine getting hot? If it is too hot it should pop the radiator cap, water will run out on the ground or the overflow bottle fills up. If you got the engine too hot, it could have caused a bunch of problems. Any water in the oil, oil in the water? Is there coolant flow through the radiator, maybe an air bubble somewhere?
Aug 31, 2009 at 5:59 AM
MOKEA
[quote:bc0ccad082="jdl123"]Other than the temp gage, are there any other indications of the engine getting hot? If it is too hot it should pop the radiator cap, water will run out on the ground or the overflow bottle fills up. If you got the engine too hot, it could have caused a bunch of problems. Any water in the oil, oil in the water? Is there coolant flow through the radiator, maybe an air bubble somewhere?[/quote:bc0ccad082] I have heard the water bubbling but turn off the engine b4 it did anything else. I've seen steam coming from the air duct.yesterday I saw some water(brown tinted) leaking out from the engine
Sep 3, 2009 at 6:47 PM
JDL
  • 16,098 POSTS
If you have a water leak, you need to find it.
Sep 4, 2009 at 1:35 AM
