Air Conditioning
SSSHINE2121
03 Chevy Silverrado, air conditioner will at times freeze
you out and there are days when it will not work at all. Some days it will kick off and on-go from blowing cold air to straight hot, back and forth. What could it be. The coolant is great, does not need to be recharged.
Aug 1, 2007 at 6:36 AM
JELLYBEANZ
2004 Chevrolet Silverado, same issue.
I brought my truck to a repair shop and this is what they told me:
Your vehicle has two actuators, if you have dual climate control (which is what I have). and the actuator on the driver's side is out. The driver's side is where I have my problems. It is really pricey to fix, so see if it's under a warranty or something. My estimated cost was $800.
My problems were similar to yours. My a/c, even when on full-blast cold will switch to the heater. My solution? Don't use the heater, and bundle up. Use the a/c, if it works. It's really sporadic.
(Hopefully you don't live in a place where there's seasons :) )
Aug 6, 2007 at 7:24 AM
