Drive Train Axles Bearings problem
2008 Chevy Silverado V8 Four Wheel Drive Automatic 6000 k miles
Through much research, I narrowed down a leveling kit made by Truxxx to raise my front end of my 2008 Silverado 2.5 inches with shims on the coil-over unit and the rear 1.25 inches. It just gives the truck a better stance. Now that this is installed, I was wondering about the front CV arms new angles? Will this cause premature wear? It is the minimum lift available, that is why I chose it. also there is a LOT of people out there installing this kit.( I had mine done by a certified Garage that is a distributor and stocks this type of leveling kit. Your answers might help all of us out there to do or undo this procedure. Thanks. My new Chevy with the kit installed is behind my old 94 that has 300000 k on it and has had a 3" body lift since new with no problems.
Ron[img:af93e723a0]http://www.2carpros.com/forum/automotive_pictures/284323_IMG_3340_1.jpg[/img:af93e723a0]
Dec 10, 2008 at 9:17 AM
