2004 Chevy Silverado replaced computer
280,000 MILES • V8 • 2WD • AUTOMATIC
BIGJON4X4
My truck was stalling out. I had it checked dealer said bad computer. I got one and installed it now it will not start.
Oct 30, 2010 at 12:09 PM
WRENCHTECH
  • 20,758 POSTS
No, it won't. It has to be programmed by the dealer and the Passlock code re-learned
Oct 30, 2010 at 12:15 PM
BIGJON4X4
the computer I bought was programed (Flashed) for my truck. You said I need to have dealer relean the computer? I lave found Some steps on line to reset . I have night checked to see if this works the battery is down. I put the charger on for now. Do you know any reason why I shouldn't do this my self. I am not able to get my truck back to the dealer. Thanks for the help
Nov 2, 2010 at 12:18 PM
WRENCHTECH
  • 20,758 POSTS
You can do the Passlock relearn yourself.
30 Minute Re-Learn Procedure
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON (vehicle will not start).
3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes ( the vehicle is now ready to relearn the Passlockâ„¢ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK).
Important
The vehicle learns the Passlockâ„¢ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine (the vehicle has now learned the Passlockâ„¢ Sensor Data Code and/or password).
7. With a scan tool, clear any DTCs if desired (history DTCs will self clear after 100 ignition cycles).
Nov 2, 2010 at 12:22 PM
BIGJON4X4
Thanks for all your Help. This is a great site! I am new on this site. I will be back to use this site again. I am not sure how the points & donation work? I will try to give a donation or point if I can get it to work. THANKS again.
Nov 6, 2010 at 11:26 AM
WRENCHTECH
  • 20,758 POSTS
The donation is for the site to help keep it running. The points are like brownie points for me to assign when you leave positive feedback. The more points I accumulate, the better I look to customers looking at my profile.
Nov 6, 2010 at 11:32 AM
BIGJON4X4
Hi, I got the donation to go, I also gave you the points that I had (I am not sure How I got the points) It all went very well easy to do. If I can doing any thing more let me know.
Nov 6, 2010 at 11:55 AM
WRENCHTECH
  • 20,758 POSTS
I'm not sure myself but I think you get the points just by posting questions.
You already took care of me so i hope I can help you again in the future
Nov 6, 2010 at 12:05 PM
