2002 Chevy Silverado Transfer Case leaking at seal
101,000 MILES • V8 • 4WD • AUTOMATIC
GRENADE
In the last several days, the transfer case has developed a leak either at the seal between the two halves or around one of the bolts that hols the halves together. Two questions: is there a way to fix this by adding a liquid sealant to the transfer case, and second, about how much should this repair be at the Chevy dealer?
Oct 15, 2010 at 1:04 PM
  • 110,248 POSTS
As far as a price, it is hard for me to tell because I don't know where the leak is coming from. It shouldn't take much more than 3 hours labor to remove replace a gasket and replace. As far as the parts, gaskets are cheap.
If you wipe everything off, can you tell where the leak is coming from?
Oct 15, 2010 at 2:50 PM
GRENADE
best I can tell its either leaking through the seal or from one of the bolt holes...its not coming from a hole in the case itself, I'm sure of that...
Oct 15, 2010 at 2:58 PM
  • 110,248 POSTS
Chances are a new gasket will fix it. As far as the additives, if they work, it is only a temporary fix.
Oct 15, 2010 at 4:39 PM
