2002 Chevy Silverado possible oil contamination w/gas
2002 CHEVROLET SILVERADO
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
WYATES
when started cold lifters noisey oil pressure erratic , stabilizes after a few minutes, and lifters quiet down, after oil change everything normal. till 1500 to 2000 miles. truck performance not effected. hard to tell if oil is contaminated by site.....is this common problem for this truck.........leaking injectors after turning off truck........leaking intake manifold................like any troubleshooting help.
Feb 22, 2009 at 12:37 PM
RHALL77
  • 3,361 POSTS
use a fuel pressure gauge to see if it looses pressure while sitting witht the engine off. if it does, block the return line and see if it looses pressure again. if it does take a look at the injectors for possible bleeding down
Feb 23, 2009 at 2:12 AM
