2000 Chevy Silverado Throttle Body
MGEE
  • 11 POSTS
Engine Performance problem
2000 Chevy Silverado V8 Four Wheel Drive Manual 98k miles
I've seen the throttle body spacers advertised to increase horsepower at mid and low range. I am wondering if there's an aftermarket throttle body assembly that provides additional performance gains. If there is, I'd install both at the same time rather than do the spacer and go back later to replace the throttle body. Every website I look, the throttle body assembly doesn't advertise a gain - just a replacement. Thanks for your help!
Oct 31, 2010 at 5:52 AM
HMAC300
  • 48,601 POSTS
ven fi you put the spaceron you won't notice a gain, at least in performance. ou mightcheckwhat holley has to offer and see what CFM it flows. If it's larger than stock thenit would give you some gain but not worth the money as far as i'm concerned.....
Oct 31, 2010 at 1:38 PM
