2000 Chevy Silverado rear end
90,000 MILES • V8 • 2WD • AUTOMATIC
FRANK15
When I take off, as I start to move the truck jumps. It feels like someone just ran into the back. It feels like it comes from the back end. What is the problem and how urgent is it? can I fix this myself?
Nov 18, 2009 at 11:19 PM
DENNYP
  • 1,824 POSTS
Does it also make a "squawk" or "thump" noise when this happens?
Nov 20, 2009 at 4:51 AM
FRANK15
Yes it did make a thump. However it is running fine now. I asked around town and shoulder shrugs was a typical response. One guy said that if the truck was running hot -( I had been driving almost all day)- then that could have been the problem. He suggested transmission fluid change and use an addative LUCAS OIL for transmissions. Your thoughts...
Nov 20, 2009 at 5:57 AM
DENNYP
  • 1,824 POSTS
get some nickel anti-seize from your local parts store.
Remove the rear driveshaft from the truck.
Brush a good amount of the anti-seize into the driveshaft yoke splines.
Install the driveshaft. (make sure to slide it several times on the transfer case output shaft)
Drive the truck to verify the problem is fixed.
With the description you are giving me, It sounds like the driveshaft yoke is binding on the output shaft.
Nov 23, 2009 at 12:58 AM
