2000 Chevy Silverado Gear Black Lash Tolerance
160,000 MILES • V8 • 4WD • AUTOMATIC
MO. MULE
I'm wanting to check my gear lash and I'm looking to confirm a reading of 0.006 to 0.010.
May 15, 2009 at 1:46 PM
BRIAN 1
  • 1,030 POSTS
here's backlash,0.003-0.010 in this is preferred back lash 0.005-0.007 in.
May 16, 2009 at 12:57 AM
DR LOOT
  • 2,311 POSTS
sorry for the intrusion but I needed the $0.25 cents, I worked at the Chevy dealership for many years doing most of the rear end work, when resetting up rear ends the factory wanted me to do them to 0.000 in. that is correct, no backlash, when the gears are new, if they are used then you are correct 0.005-0.007 in. when setting up the gears keep in mind that paper is 0.003 in. and don't get confused the backlash in the spider gears
May 16, 2009 at 5:22 AM
