2000 Chevy Silverado FUEL PUMP
MGEE
  • 2000 CHEVROLET SILVERADO
  • V8
  • 4WD
  • MANUAL
  • 99,700 MILES
What's it cost to replace a fuel pump with a GM fuel pump? Where to I go to get it?
Thursday, September 30th, 2010 AT 10:02 PM
  • 109,885 POSTS
A GM pump will come from a dealer. As far as the part, if it is OEM, expect the cost to be aroung 300.00. Aftermarket ones are about half the cost.
Friday, October 1st, 2010 AT 8:16 AM
MGEE
  • 11 POSTS
Thanks for your help! I found it much easier to remove the bed of the truck, as opposed to dropping the fuel tank. Took about 1 hour.
Sunday, October 31st, 2010 AT 1:06 PM
  • 109,885 POSTS
I couldn't agree more. It is easier to remove the bed, but when I suggest that, most people think I'm crazy.
Did it take care of the problem?
Monday, November 1st, 2010 AT 1:19 PM
MGEE
  • 11 POSTS
Yes and No! HA! I bought the Aftermarket option b/c it was 150 bucks cheaper. About 3 months later, I began having problems starting it after it had warmed up. Every morning, it starts without any issue. Then 4-8 hours later, it takes about 15 seconds before the engine actually turns over. Once running, it doesn't give any problems. I am looking into Fuel Pressure Regulator and a few other issues. I did purchase a fuel pressure gauge, and my readings are within specs. I will repost if/when I resolve the issue! Thank You again!
Saturday, April 9th, 2011 AT 3:27 PM
