1999 Chevy Silverado WANT START
JOHN H PAGE
  • 1999 CHEVROLET SILVERADO
  • 6 CYL
  • 215,000 MILES
GOT WATER IN FUEL TANKS WOULD NOT START, CHANGE FUEL FILTER & PLUGS STARTED AND GOT HOME. WOULD NOT START. PUMPED OUT TANKS & CHANGED FUEL AGAIN & PLUGS STILL WILL NOT START
Tuesday, February 2nd, 2010 AT 10:36 AM
2CARPRO JACK
  • 11,533 POSTS
Does it have fuel pressure? If so how much. Will it fire up if you spray carb cleaner in the throttle bore? If you have pressure, ou should take a fuel sample at the engine to see what it looks like
Tuesday, February 2nd, 2010 AT 3:20 PM
JOHN H PAGE
  • 6 POSTS
YES, PSI IS ABOUT 65, NO WHEN SPRAY WITH CARB CLEANER
Monday, February 8th, 2010 AT 9:10 AM
2CARPRO JACK
  • 11,533 POSTS
How about spark? Those had problems with crank angle sensors, which would cause a loss of spark
Monday, February 8th, 2010 AT 11:32 AM
JOHN H PAGE
  • 6 POSTS
Yes it has spark
Monday, February 8th, 2010 AT 11:52 AM
2CARPRO JACK
  • 11,533 POSTS
Thats odd, if it has spark, it should start with carb spray sprayed into it. May want to try that again. Check all fuses with a test light too.
Monday, February 8th, 2010 AT 9:44 PM
JOHN H PAGE
  • 6 POSTS
Could it be some code in the computer that needs to be resit
Tuesday, February 9th, 2010 AT 9:10 AM
2CARPRO JACK
  • 11,533 POSTS
No, codes wont keep it from running. If it has spark out of the coil, be sure it has it at the plugs.
Tuesday, February 9th, 2010 AT 1:04 PM
