1999 Chevy Silverado trouble code P0440
1999 CHEVROLET SILVERADO
LA GANZA
  • 44 POSTS
Engine Mechanical problem
1999 Chevy Silverado V8 Four Wheel Drive Automatic
Hi I have 99 chevy silverado 4x4 auto V8 I need to know how to fix trouble code P0440 any idea? thanks
Feb 27, 2009 at 3:09 PM
You got a lot of vehicles that we have helped you sounds like a sideline job
A code P0440 could mean one or more of the following has happened:
The gas cap is not installed or working properly
The purge solenoid has failed
The canister is plugged and not working properly
Possible SolutionsWith a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
Inspect the EVAP system for cuts/holes in tubes/hoses
Inspect for damaged or disconnected hoses around the Evap purge solenoid
Check and/or replace the sensor
Check and/or replace the purge valve
Have a professional use a smoke machine to detect leaks
Feb 27, 2009 at 3:21 PM
