1998 Chevy Silverado
PETEC
  • 1998 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 20,400 MILES
My truck shutters from 35mph to 65mph but only when you are just trying to maintain speed not accelorating
Friday, September 18th, 2009 AT 6:27 PM
If the tranny is okay could be one of the following that's causinng it:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Friday, September 18th, 2009 AT 7:20 PM
