HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Silverado
Engine
Symptoms
Sputter
1997 Chevy Silverado spits and sputters when accelaterated
OLDDUDE55
MEMBER
1997 CHEVROLET SILVERADO
V8
2WD
AUTOMATIC
150,000 MILES
Kinda sounds like bad plugs or wires engine runs fine unless you gas it, then it just kinda back fires or misses.
Tuesday, June 29th, 2010 AT 9:33 AM
MECHANIC
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
SPONSORED LINKS
Tuesday, June 29th, 2010 AT 7:02 PM
Please
login
or
register
to post a reply.
Related Engine Sputter Content
2000 Chevy Silverado Shudder
I Was Told I Have A Launch Shudder Problem, Vibration At Take Off Worst Pulling A Trailer At Take Off But Stops After 10 Sec. Was Told To Go...
Asked by
dakota2010
2000
CHEVROLET SILVERADO
1992 Chevy Silverado Stuttering
My Old Truck Has Recently Had An Issue With Stuttering And A Loss I Performance. When I Start It Up It Runs Great But Then After A Few...
Asked by
wannagofaster
1992
CHEVROLET SILVERADO
What Causes The Sputtering When I Use My A/c? Can I...
2008 Silverado 1500, V6, 2wd, 27xxx Miles My A/c Comes On With A Thunk And Something In The Front End Sputters And Shakes, Reminiscent...
Asked by
gregmarshall
1 ANSWER
2008
CHEVROLET SILVERADO
Shudder
2005 Chevy Silverado V8 Four Wheel Drive Automatic 2005 Silverado 1/2 Ton, 57,000, Between 45-60 Mph In 2wd Get A Constant Shutter...
Asked by
jfaiella
1 ANSWER
2 IMAGES
2005
CHEVROLET SILVERADO
2004 Chevy Silverado Shutter, Shakes, Rpm Changes...
Shakes Or Wobbles Problem 2004 Chevy Silverado V8 Two Wheel Drive Automatic 90k Miles When Under Light Load The Truck Shutters, And...
Asked by
shepherdk
2004
CHEVROLET SILVERADO
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Honda
How to Read Codes Chevrolet
Check Engine Light Safe to Drive?
Online car repair manuals
