1995 Chevy Silverado Antifreeze on TOP of Intake manifold
165,000 MILES • V8 • 4WD • AUTOMATIC
RYAN1959
My truck was steaming after a small trip and I opend the hood to take a look. I notice antifreeze on the top of the intake manifold. I dried the intake with a towl and replaced the thermostat and tstat gasket. I siliconed properly and let dry overnight. Next day, started it up and the antifreeze started pooling up on the RIGHT side of the intake manifold again. NOT leaking from thermostat. Where is the fluid coming from and will it be super hard to fix? I am assuming from the clynder cover, but I am not a mechanic.
Aug 20, 2009 at 7:51 AM
MERLIN2021
  • 17,250 POSTS
Unless it's leaking from a heater hose, then it could be the intake manifold gasket, how does it run? Very rough?
Aug 20, 2009 at 7:59 AM
RYAN1959
Runs okay and none of the hoses are leaking. IT just pools up at a constant rate. Could it be coming from the valve covers area?
Aug 27, 2009 at 12:58 PM
MERLIN2021
  • 17,250 POSTS
Not unless it has a cracked head. Intake manifold would be the leak, remove and replace the intake gasket, and check manifold for striaghtness.
Aug 27, 2009 at 7:25 PM
