1992 Chevy Silverado falling dead at red lights, stop sign
CAPT. CURT
  • 1992 CHEVROLET SILVERADO
  • V8
  • 252,345 MILES
Truck falls dead at red lights. Stopsigns or whenever it desires to. I have already put plugs and wires as well asthe fuelfilter this is the reason I changed the parts in the first place but the promblem continues. What could my problem be?
Wednesday, December 9th, 2009 AT 7:58 PM
JDL
  • 16,098 POSTS
Welcome to the forum, any trouble codes? Take the throttle-body off and clean it. Maybe Issue with iac system? Use a gage and check fuel pressure.
Thursday, December 10th, 2009 AT 10:06 AM
MICHAELPOE75
I am working on a 93 that has the same problem. Will run great for a few days and then will not hardly run at all. The exhaust system had been completely replaced on the truck before I started working on it. If u pump the accelerator when it tries to die, you can keep it running. So hard to find these intermittent problems. No codes on scan. When u hook it up to computer, it shows everything working correctly.
Monday, December 28th, 2009 AT 4:14 PM
JDL
  • 16,098 POSTS
I agree with you, intermittent issues can be hard to track down. You have to do the testing when the problem is ongoing or you can't find anything.
Tuesday, December 29th, 2009 AT 10:01 AM
