I just completed an installation of a 400 SBC into my 1991 Silverado C3500. Transmission is a 4L80 automatic. The engine is.030 over with a EFI cam and 9.5:1 compression with aluminum 63cc heads. Originally equipped with a 5.7 it ran great 3 days earlier but upon installation and proper cam break in (according to the engine builder) I found the truck will not hold an idle nor a steady cruise. Being an expert in hit and miss diagnostics I decided to install a new Air Idle Control Valve, Throttle Position Sensor, Knock Sensor, Temp Sensor, MAP sensor, O2 sensor, Ignition Module, Fuel Pump, Filter & Pressure Regulator, New cap Rotor & Ignition Module and missed every time, I decided to limp it over to a local ASE Certified Shop After a week and two hundred bucks in incidentals later, they were baffled and suggested that I take it to the engine builder to consider an engine build issue.
After a week at the reputable builders hands and several hundred more dollars they said the engine was solid and sound and maybe a new computer or new distributor or even a new TBI on top. I suspected a faulty ground strap so I confirmed a quality ground from battery to engine block to chassis to cab and even grounded the exhaust pipe (single wire o2). With no issues of any vacuum leaks, just don't know why the truck can't find a steady idle, it seems to jump idle up and down and stalls frequently. What do you suggest? Do I need to have the computer flashed? 454 injectors? ECM? Distributor? P.S. I have deleted the EGR valve.
SPONSORED LINKS
Tuesday, February 2nd, 2010 AT 10:02 PM
